M43 Part out
Posted: Thu Jul 31, 2008 6:28 pm
by xm708
Guys I am parting out an M43 here real soon. The body is rotted bad so not much there. Rear doors are definately useable strecther parts are there little lift doors under the stretchers are there bunch of little stuff. I do not like junking these things but the body is trashed. I am keeping the running gear for awhile but the body is going to the scrapper here pretty soon full of steel scrap so any parts needed speak up. I do not want to make a killing I have already broke even on the truck.
thanks
ed
in the north east rust belt
Posted: Thu Jul 31, 2008 6:32 pm
by k8icu
I need the brackets for the marker lights and the black out drive lights on the front fenders any chance you might have them? I'm also in need of a transmission cover...the one inside the cab the bolts to the floor mine is beyound repair. I need some other body parts, but thought I'd might have a shot at those not being to rusted out....:)
Joe
parts
Posted: Fri Aug 01, 2008 4:28 am
by xm708
I believe all that stuff is there I will check tonight and PM you.
thanks
ed
picture is in the registry just look under the state of vermont and it is the only m43.
M43 Rear driveshaft?
Posted: Mon Aug 04, 2008 9:07 am
by Drew M.
I may need a slightly longer rear driveshaft for my M37.
If avail., shoot me a pm. Thanks from PA.
Posted: Mon Aug 04, 2008 8:18 pm
by mbwarner
I could use and oil bath air cleaner assembly, if one's there.
Posted: Fri Aug 08, 2008 4:54 am
by Larry S
I need the sheet metal that the rear compartment gas heater attaches to, to direct the heat into the patient area
M43 parts needed
Posted: Tue Aug 12, 2008 5:08 pm
by Mobilized Medic
YO XM!
Need litter racks,interior tie downs and rear doors. What condition are the rear doors, any weld-up needed?
Located in northcentral Wisconsin the "other" rustbelt.
Regards, Mobilized (and tired of patch welding) Medic
