Removing passenger side running board
Posted: Sat Jul 05, 2025 5:07 pm
by JimC
On the 708. It was only 91° at lunch, so I crawled up under the sucker, blasted it with Kroil, and drug out the rachet and 9/16" socket. I lasted about ten minutes, gave up, and went home to soak up some air conditioning. By 5 o'clock it had cooled down to 89° so I tried again, this time sitting on a stool instead of lying in the gravel. Got 3 of the 4 bolts out. Gonna have to drill the head off the 4th tomorrow morning before it gets too hot.
Re: Removing passenger side running board
Posted: Sun Jul 06, 2025 11:04 pm
Jim,
I would just snap off the old heads and use fresh fasteners-saves a lot of sweat.
Posted: Mon Jul 07, 2025 2:52 pm
by JimC
I'll be using fresh fasteners, but the old heads don't snap off.
Edit - I got it done today.
Posted: Mon Jul 21, 2025 10:03 pm
by JimC
Trial fitted replacement passenger side running board. My front support bracket is bent slightly aftward, so will need to straighten that before bolting in.
Where can I get large head carriage bolts in 5/16-18x1" ?
Posted: Tue Jul 22, 2025 7:02 am
by just me
Since the correct bolts aren't readily available, I used elevator bolts. The head is the right diameter. But is flat. I get them at my local hardware store. (McFadden-Dale) McMaster also has them.
Posted: Tue Jul 22, 2025 8:23 am
by JimC
I found a source for large head carriage bolts this morning. Ordered 25.
Posted: Fri Aug 22, 2025 3:25 pm
by John Mc
JimC wrote: ↑Tue Jul 22, 2025 8:23 am
How about sharing that source?
Posted: Fri Aug 22, 2025 4:03 pm
by JimC
5/16×18×1.25" large head carriage bolts from bolts-n-nuts
- Screenshot_20250822-185915_Gmail.jpg (109.6 KiB) Viewed 39425 times
Posted: Fri Aug 22, 2025 5:00 pm
by John Mc
For those looking for the actual link, here it is:
https://www.ebay.com/itm/185630168180
