Page 6 of 7
Re: My AF truck's jolt of progress...
Posted: Wed Feb 05, 2014 11:07 am
by vtdeucedriver
w30bob wrote:Hi Guys,
Here are some pics of the firewall insulation padding in my AF M37. The padding looks to be made of three layers of paper hardboard followed by what looks like layers of corrugated cardboard. I picked up the firewall insulation set from John at Midwest last year.........opened the box....and wasn't impressed...........looks like posterboard I can get at Micheal's craft supply for a buck a sheet. I put it in the corner and will deal with it later down the road, as I'm no where close to that phase of the project. I figure worst case I can use them as patterns if I ever find the correct padding material.
DSC05457 by
w30bob, on Flickr
DSC05458 by
w30bob, on Flickr
Refit.....question about your data plate.......did you copy that info from your originals? Reason I ask is you stamped in Air Force for the Responsible Agency for all 4 categories. The data plate on my AF truck is stamped ORD DEPT in all those places. I've never seen a data plate that was originally stamped AIR FORCE........so I'm just wondering.
. by
w30bob, on Flickr
This is correct!!! I have a NOS section and it is pretty thick and cardboard like. After seeing the differences in Bizal's replacements I might just hold out a bit longer to find the other piece I need to complete or I will cut my own heavy cardboard and glue some thick poster board over the top. I would think by doing that, it would get a bit more accurate.
Next time I see my piece, I will get a pic of it for reference.
Re: My 1953 Air Force M37 Build Blog
Posted: Mon Mar 10, 2014 8:10 am
by refit1701
Had the first nice day of March on Sunday and we got some work done. Got all the gauges installed and final wiring done for them. Finally replaced the 120psi oil gauge with a 60 to match the sender. Speedo cable installed. Starter panel and transmission hump are in. Replaced the small ground cable from the frame to the engine pack with a heavy one inch unit.
Wired up the dimmer switch and.....the truck was fine until I hit the switch to test it. Low beam position killed the electrical system. No sparks but gauges went dead. A little testing and out comes the new dimmer switch for diagnosis. The sealed unit had a intermittent dead short across one side. We un-crimped it and found they had crimped a "U" shaped retainer on the wire just behind the bullet connector a little too vigorously, resulting in a short. We fixed that and re-crimped it back and now all is well. Headlights work as they should without shutting the truck down!
I got all the harness retainers for the inner fenders painted and installed, next will be completing the headlight harness final hookup.
Now if I could only find the missing headlight trim ring for the passengers side.....
Posted: Mon Mar 24, 2014 5:02 am
by refit1701
Posted: Sun Apr 13, 2014 8:55 am
by refit1701
Posted: Sat Apr 19, 2014 7:25 pm
by refit1701
Well, did some more work on the truck. My plan to do 30 minutes minimum a day is paying off. I got my shifter cleaned, painted and installed. The transmission is much better behaved with the correct unit. Today we spend four hours adjusting the brakes which was a job to say the least. With warped drums, none of them could be made perfect but I expected that. We started on the fronts and after they were done I had plenty of pedal!
I'm still painting small parts and maybe I can clean and prime the bumper tomorrow. I need to install the blinker unit for the lights and then hook all that up.
Posted: Sun Apr 20, 2014 1:30 pm
by refit1701
Posted: Sat Apr 26, 2014 12:57 pm
by refit1701
Moving along, I got the bumper and shackle brackets done and added them to the truck:
Now, the job I have been putting off is finding and cleaning a gas tank. I am beginning to believe they were equipped with rust from the factory, as none I have seen are even the least bit rust free on the inside. It's only a matter of degrees. Of course, it turned into a major job getting the sender two plates loose from the tanks so I could see inside.
Chemical soak then impact each had their turn and I still broke off screws.
Once I got the fuel pickup plates off of two of the tanks, the different versions were obvious:
Here's the old in tank filter with Midwest's replacement:
I'm thinking the black one is going to be the choice. It will still need to be etched and lined with tank sealer. This is a messy job and it's a pain but one more hurdle to be jumped.
I'm getting my primed tailgate, toolbox doors and hinges tomorrow. So more painting after the storms they are predicting for the first of the week.
Posted: Tue Jun 10, 2014 7:57 pm
by vtdeucedriver
UM its JUNE!!!!!!
Posted: Wed Jun 18, 2014 4:11 am
by refit1701
And your point is?
If I had the door glass in and the odd governor issue fixed, I'd be at the nearly 98% done stage that all our trucks seem to hover at. If I can't get the governor worked out by Friday PM, no first MV show for it until late Fall. Stencils have to wait until the paint is cured all over, so I can just mask everything once.
Posted: Sat Jun 21, 2014 10:33 am
by k8icu
Nice Job! Would love to see it up close. Driving to Ohio anytime soon...
Posted: Sun Jun 22, 2014 5:59 pm
by refit1701
Ohio? EEK, I just drove 50 miles to my first show and that was a chore!!!
Posted: Wed Jun 25, 2014 1:48 pm
by vtdeucedriver
refit1701 wrote:Ohio? EEK, I just drove 50 miles to my first show and that was a chore!!!
MAN UP!! I just did a 200 mi round trip for a Living History show.
You just got it done, no complaining.
Posted: Mon Jul 14, 2014 10:00 pm
by RMS
vtdeucedriver wrote: You just got it done, no complaining.
yup no need for a gym membership when you own a m37
Posted: Mon Oct 27, 2014 4:28 am
by onemanarmy
refit1701 wrote:Pictures!!
Firstly, this was the truck a week ago when my daughter and I went for a ride in the yard for the first time.
These are those gauges you can buy (repros) out of Supply Line. They are very nice looking but not 100% like the real thing. The only issue I have is the oil pressure gauge is a 120 type and I need a 60psi gauge. So now I have all new units except I will probably have to use an old gauge for the oil, which won't match. Grrrr....
Do you remember the part number or site you purchased these gauges from?
Posted: Sun Nov 02, 2014 3:12 pm
by refit1701
Midwest, Army Jeep parts, etc., sell those gauges. They are nice repros. Be sure of which sender you have for the oil pressure as I bought the four gauges and then discovered I needed a 60psi gauge, not a 120.
