Page 6 of 12
Re: 1955 m 37 cannadian build, lots of restoration pictures
Posted: Sun Jun 13, 2010 3:41 am
by Monkey Man
Master Yota wrote:
powerwagontim wrote:When you had your drum turned, was it mounted on its hub? If not, it will make a really nice ashtray!
Tim
Are these drums different than all the other brakes drums that are turned without a hub? Is the center hole not round, or offcenter? What gives?
They will be fine, they cut like any other drum, I had mine recut (prior to me fitting discs) and they worked a treat, the only thing I had to do was get a cone sleeve turned up so the larger hub diameter was accomodated. The main reason I went to discs was stopping power and parts availability being that I am in a somewhat remote location for M37 parts supplies and my drums were getting to their final cut anyhow.
Regards - MM :-)
Posted: Sun Jun 13, 2010 4:16 am
by powerwagontim
The drums are lug-centric, not hub-centric. The large hole is not necessarily concentric to the braking surface. To turn them correctly they need to be mounted onto a hub, and the hub chucked into the lathe. A lot of good drums have been ruined turning them without the hub. If you did it and had good results, great, but I think you got lucky.
Tim
Posted: Sun Jun 13, 2010 6:20 am
by paul
ahhh that is why it catch a little more on one spot! ill try them up since they adjusted pretty easy , but ill get the front one turn with the hub, thanks for the info, i still got 8 more good drum here so if i got them out of round ill be able to get two ore turned, i will have lost two drum and 50 bucks!
Posted: Mon Jun 14, 2010 12:52 pm
by paul
well today i got just a little done , i spended some time i the flowers and putting ligth up outside to keep my girlfriend happy...lol , so i got one top shock mount sanded and etched, and i got the bolts for the shock mount ready to paint, and i started fidling with one of the front leaf pack
anyway here are the pics of the day, enjoy!
rear shock mount at the frame etched
bolts for rear shock mount clean and ready to paint
the front leaf pack i started fidling with
Posted: Tue Jun 15, 2010 1:19 pm
by paul
well today was a story about cleaning and prepping more parts for paint, got lmost all of one leaf pack done , go some hardware ready and got both rear shock mount clean and etched, did i mention i hate sandbasting, got some glass bead all the way where the sun don't shine!
anyhow here are the pics of the day, enjoy!
leaf that are left to prep of the first front leaf pack
i had to remove those from the part truck as mine where in ruff shape!(shown here)
the parts i preped today
slow but sure! lol
Posted: Wed Jun 16, 2010 1:10 pm
by paul
well today i started by sanding the remaining leaf ad etching them, then i went on painting the part that where preped yesterday, after that i instaled and assembled said parts , i could not get the leaf back on the frame as i picked up the wrong bushing ,ill have to go down and get the rigth one this week end, then i attacked the mangled and bent rear ligth bracket, tha driver side had to be straigtened and a few crak needed fixing but the passenger side was a mess o welding and bubble gum, so out come the grinder and the torch then the welder and a few hour later i have a bracket that looked like new, i love metal work, i find it relaxing!
anyhow enuf blogging, here are the pics of the day, enjoy!
an other bunch of parts painted and ready to be assembled!
got the shock bracket on with new bushing
the bushing where new old stock i got for 2 buck each, they where i very good shape not bad 8 buck a shock for all new rubber!
got the passenger side front leaf pack back togheter
the worn bushing and the wrong one i picked up that prevented me from getting my leaf hanged
the passenger side ligth bracket in peaces!
the back welded
the front welded and clean up some
all sanded and ready for etching!
my ligth bracket all etched!
still slow but sure!
Posted: Wed Jun 16, 2010 6:54 pm
by Monkey Man
powerwagontim wrote:The drums are lug-centric, not hub-centric. The large hole is not necessarily concentric to the braking surface. To turn them correctly they need to be mounted onto a hub, and the hub chucked into the lathe. A lot of good drums have been ruined turning them without the hub. If you did it and had good results, great, but I think you got lucky.
Tim
I agree with that sort of Tim but I was curious as to how they were actually done so I contacted my friend Bill and asked how it was gone about, he said that he measures and centres the drums manually and the cone is mererly to lock the drum onto the adjustable hub, the machine spindle is then adjusted to match any run-out from centre. He also said that he has had to trash quite a few drums that were stuffed by "clever" folks (like the ones you speak of) that so "know" how to do these things. Bill knows what he is on about and has cut countless drums and discs over the years so he said to tell you that there was no luck involved, just a good set of measuring calipers, a dial guage, a good machine and a good eye for the job.... Oh - and he says to say G'day to all the folks on here too (he loves my m37) :D
Best Regards - MM :D
Posted: Wed Jun 16, 2010 7:20 pm
by powerwagontim
M.M.,
OK, I will revise it to "you were lucky to have someone who understood how to do it, rather than the just chuck it in the lathe like a run of the mill drum kind of guy" Sounds like Bill is good at what he does, and knowledgable of the practical theory involved.
Tim
Posted: Wed Jun 16, 2010 9:52 pm
by Monkey Man
Don't worry Tim, I wasn't having a go at you, you just piqued my curiosity so I asked the question of Bill and have gave the answer. Bill is the sort of bloke I gladly get work done with, I would easily trust him with my life as I have known him most of my life and always been amazed as to some of the things he has built and repaired, a skilled man indeed....
Best Regards - MM :-)
Posted: Thu Jun 17, 2010 10:54 am
by M37UK
[quote="paul"]well today i got just a little done , i spended some time i the flowers and putting ligth up outside to keep my girlfriend happy...lol , so i got one top shock mount sanded and etched, and i got the bolts for the shock mount ready to paint, and i started fidling with one of the front leaf pack
What type of etching primer do you use?
Stu
Posted: Thu Jun 17, 2010 11:24 am
by k8icu
M37UK wrote: What type of etching primer do you use?
Stu
Yeah what he said! My question too as I'm starting to think down the road as to what I need.
Posted: Thu Jun 17, 2010 11:57 am
by m-37Bruce
This is what I've been using on bare/clean metal;
http://shop.advanceautoparts.com/webapp ... RP2050____
After that, used Gilespie Coatings Red Oxide.
Posted: Thu Jun 17, 2010 12:55 pm
by paul
wich ever primer is on sale , but i alwars make sure it is self etching primer difference being it does not need an other layer of primer over the etch, i used the dupont stuff and the duplicolor mostly i like it better in areosol so it make less fidling with the gun
well today was a productive day! i got my tire back from the tire shop, they carged me 28 buck a tube! ouf i needed 3,then i got the shackle off the remaining front leaf, i had to fix the stop on the retaining shackle, then i got the driver side front leaf pack appart, it was all crooked ,probably got a good hit on that side in time, got all the leaf cleaned and etched and back togheter with a new center pin, i painted everything i had clean and preped, plus i had the time to start cleaning the bolt for the bumpstop in the front and cleaning the rubber on the bumpstop.
tires are back from the tire shop!
stop all mangled on the shackle
all fixed!
more stuff etched and ready to paint!
and painted!
rear ligth bracket in place!
front driver side leaf pack back togheter
bumpstop bolt cleaned and ready for paint!
and i got a hose on the breater of the rear end, not orriginal but it will beat changing the oil every time i hit water with it
Posted: Fri Jun 18, 2010 2:29 pm
by paul
well today i got some ore stuff preped and etched, like the front bump stop, the front u bolt and hardware, the case for the differential even had some moss growing on it before i started et it!
just a few daily pics , enjoy!
the morning production!
the gear case before and after, the green stuff on the before picture is moss!
before
after!
and the final production of the day resumed to this! almost enuf stuff to get the gun and the black paint out!
slow but sure from beresford!
Posted: Mon Jun 21, 2010 12:26 pm
by paul
roadtrip day! today me and my girlfriend went to get some parts at mr.mazerolle, came back with new bushing for my front leaf and some brake shoe and a hand brake linning! so all my brake will be new
his parts truck and vehicule he has there, the tractor trailer container in the background also have nos part in there
new bushing
new brakes
hand brake lining
paul
