Re: Change of plans, AGAIN!
Posted: Sat May 28, 2011 8:55 pm
Got my plate. Licensed, titled, and registered under me and my dad in Michigan. Threw together the last few bits and took it for its first ride tonight. It's quite amazing the amount of into you can gather in 15 minutes of poking around town
First, the good:
+Power. Holy Moses does it have power. I didnt even push her all the way to the floor and it makes power. 15 PSI of boost will lay you back hard in the seat for a 3.5 ton truck.
+Power steering. Power steering rocks.
+Only one leak... see below.
+The big Michelins ride pretty good.
Now the bad:
-Clutch needs to be adjusted. It goes over center and won't come up off the floor sometimes. Will try adjusting the rod first, if that doesnt work, I'll add a spring to the linkage.
-I made the gas pdeal linkage WAY to steep. Hurts the top of your foot to pull it back that far. Need to cut and reweld the linkage at a lower angle...
-I put the fuse box in a VERY bad spot. I kick it sometimes with my foot when I push the clutch down and the cover pops off and knocks the fuses out... Annoying.
-Power steeling line is leaking a little bit. No big deal, will take it to the truck place that made it and ask for a new one.
-Very darty steering. I need a longer pitman arm on the Dana 60. Darty steering on a 71/2 foot tal truck is NOT a good thing!!
-the ZF5 is making ALOT of noise from tthe front end. I was told tehy were very noisy, but this one seems rediculous. It drowns out the cummins if you lug it heavy in 1,2,or 3rd. I gotta find out if there is anything I can do for it. It sounded a lot like clutch rattle. It wasnt slipping, or chattering, its that noise you get when you lug a manual at low speed and heavy torque. keep the RPMs up, it goes away.
An interesting fact: It makes the same sorts and types of noises my Audi TT makes, just 15X louder...
First, the good:
Now the bad:
