Page 2 of 2
Re: Can't get timing right, can the oil pump gear be off by one
Posted: Mon Apr 25, 2022 7:15 pm
by Halfdunn
Thanks guys! Still stock carb and have never really messed with the Governor. I am happy at 40 mph like some of you and remember, I am pulling along 7800 lbs of weight on my USAF R-2 Rescue truck with all of the proper equipment on board. I may still tinker with the timing a little for some fine adjustment. It does fire right up without the choke pulled and seems to accel smoother. Fuel is not a issue I believe but will test pressure and float level. just got a carb rebuild kit but wanted to see what happened with the new timing first.
Posted: Tue Apr 26, 2022 4:46 am
by ashyers
If your engine is stock you won't find much in timing. If your at 2-4 BTDC these things just aren't that sensitive to it. We played with one on the dyno and advancing it up to 8 did nothing and going further didn't make much sense.
As far as the governor, there's some good posts on here of how to adjust it by Charles Talbert. He wrote up a very good set of instructions. If the governor is working correctly the truck will approach it's max RPM and gently stop accelerating. It works on a principal very similar to a governed lawn mower engine. You can adjust how aggressive it comes on, but there's limits. It can cause surging at one extreme or sluggish response on the other. If adjusted correctly it works really well.
Edit: Just dug these up, enjoy:
Edit, Here's one of the posts:
viewtopic.php ... nor#p54198
and the other:
http://www.powerwagonadvertiser.com/for ... hp?t=10947
Posted: Mon May 02, 2022 3:22 pm
by John Mc
ashyers your links are not working.
Posted: Tue May 03, 2022 7:40 am
by ashyers
We'll try that again, something was clipped when I copied them. They seem to work now.
viewtopic.php?f=3&t=6963&p=54198&hilit=governor#p54198
and the other:
https://powerwagonadvertiser.com/forums ... ng?t=10947
Posted: Wed May 04, 2022 6:06 pm
by Halfdunn
Thank you, thank you very much. I appreciate all of the archived articles and have downloaded them to my computer for reference when I start the process.
I really look forward to trying this out on my decent running M-56 chassis 230 engine.
HalfDunn
Posted: Sun May 08, 2022 5:08 am
by vit16
ashyers wrote: Tue Apr 26, 2022 4:46 am We played with one on the dyno and advancing it up to 8 did nothing and going further didn't make much sense.
amazing info!!!
