Page 2 of 3
Re: dark green canadian
Posted: Tue Sep 24, 2013 8:40 am
by RMS
iv made lots of progress over the last month.not many pics but lots of progress. I decided to make a harness from scratch. picked up 5 100ft spools of 14g wire. broke the harness down to 3 runs: rear, right front and left front. I started by laying a single wire for each run in its respected place and left long tails. better to be feet too long than inches too short. with the lengths figured out I removed the wire from the truck and stretched them out on the floor. with a separate wire for each light layed out in their respected runs the taping began. I put a small wrap of tape every 8 to 10in then fished the runs into the truck. I used heat shrink and crimps to make my connections as I am hopeless at soldering
with the wire layed and connections made i loomed up the works, well except under the dash as i still need to make a main light switch plug. and install a turn signal.
I took many breaks from wiring to paint bits and bolts I had neglected. I also repaired and installed the speed'o cable
well i should get offline and back to the shop. happy wrenching
Posted: Tue Sep 24, 2013 9:22 am
by jim lee
"I am hopeless at soldering"
9 times out of 10 its not the person, its the solder. The other one? Its the iron. Seriously its easy if you have the right stuff.
Keep the pix coming!
-jim lee
Posted: Mon Sep 30, 2013 4:17 pm
by RMS
Posted: Thu Nov 07, 2013 3:57 pm
by RMS
two weeks of pounding and the tail gate is almost strait.
Posted: Fri Nov 08, 2013 8:36 pm
by RMS
Posted: Fri Dec 06, 2013 8:45 am
by RMS
Posted: Fri Dec 06, 2013 9:26 am
by Jess
Looking Good Robyn,
Any of that white stuff over there? We had a dusting yesterday and its gotten cold. I was hoping for more sunshine but I guess the outside work is over for a bit. Did you et the tailgate finished? I'm looking forward to see how you made out with that rather ugly piece. I've located another M37 over here that is in better shape than any of mine. Now I just have to figure out how to get it home without the boss noticing...
Jess
Posted: Fri Dec 06, 2013 9:40 am
by RMS
hi jess
no snow over here, but she is cold. tail gate is finished and on the truck I will try and get pics next time she moves.
Jess wrote: Now I just have to figure out how to get it home without the boss noticing...
good score! as long as it was not a fire truck you should be able to hide it in a tree line or under some shrubs
Posted: Mon Dec 09, 2013 8:23 am
by RMS
she passed the cold start test over the weekend, my Canadian thermometer was reading -12 and it only took tens of seconds worth of cranking.
hey jess what do you think of the tail gate? it may still get a pioneer rack to hide the waves
Posted: Mon Dec 09, 2013 1:49 pm
by Jess
The gate looks great! I'll look for a before shot of when it was still on the yellow parts truck here. You've done wonders with it. I'm happy to see that it worked out for you. Now I just have to find someone to love the rest of the donor so I can bring one more home.
Have A Merry Christmas and a Safe, Healthy and Happy New Year!
Jess
Posted: Mon Dec 09, 2013 1:56 pm
by T. Highway
RMS,
The truck is looking good, the tailgate looks 100% better.
Posted: Sat Apr 19, 2014 9:36 am
by RMS
thanks Bert.
Installed a pioneer rack yesterday.......that tail gate is looking better. mount a shovel and most of the dents will be hidden.
cant get the temp gauge working. the head I installed is a early head with a small 1/2in sending unit hole. did any of the ww2 trucks come with a non mechanical sending unit? were they all like the powerwagon ? will I be drilling and tapping ?
Posted: Sun Apr 20, 2014 1:23 pm
by refit1701
Your truck is looking great and has plenty of character! Great photography!
Posted: Mon Nov 09, 2015 8:56 pm
by RMS
all right I have drug my feet for too long........the oil pressure sending unit has been fixed..... temp on the other hand........I couldn't be bothered fiddling around trying to match a sender to a gauge...it will have to be drilled and taped to accept the stock 24v sender. something the new owner can play with.
dark green canadian for sale
Posted: Mon Nov 09, 2015 8:59 pm
by RMS
the truck is listed for sale on cl :
http://vancouver.craigslist.ca/rch/cto/5446961413.html
its time to start building that 265 long rod
