Page 2 of 2
Re: voltage regulator
Posted: Fri May 17, 2013 4:07 pm
by jimmy_stikx
MSeriesRebuild wrote:This is a very good way of doing it if staying military matters. If it doesn't matter to you, a Delco-Remy 10SI, one wire set up is easy, cheap, and works very reliable.
98% sure that's the setup on my 12v setup I inherited, it has worked well so far.
Posted: Sat May 18, 2013 10:57 am
These are readily available in both 12 or 24 volt configurations. Same simple installation either way.
