Re: Brakes on M-37
Posted: Sun Feb 19, 2012 11:26 am
While talking about the steel brake lines there are two points that should be brought up.
1-Which brake fluid do you intend to use? DOT3/4 or DOT5 (silicon). The military used the DOT 5 silicon. You can flush out all traces of DOT3 or 4 but you can never completely flush out all traces of DOT5 silicon. The two types are not compatible.
There are thousands of words written on the subject of which is the better fluid to use but you should do that research via google and read up on the various opinions before deciding which fluid you want to use. Each has it's claim to fame and each has it's bad points. The type of use and environment issues are what should be used to make the decision. On these web sites it just boils over as a argument about opinions. Anyway if you choose to go with DOT3 or 4 then you will need to replace all parts of the brake system.
2-You will need to apply a wee bit more pressure to the steel lines to determine their condition. That foot pedal when applied results in a lot more than 100 PSI.
