Page 2 of 2
Re: Bruce's truck
Posted: Mon Mar 01, 2010 1:13 pm
by m-37Bruce
ron hardin wrote:Bruce,
You're the MAN. Thanks for the pics of the top of the frame showing the fittings and location. I can tell where they go but I'll have to get the pieces from John at Midwest.
Thanks again,
Ron
Ron, You can make the two inside tabs, for that matter you could make both?
I'm sure that John has 'em also, do you still have the nut in the windscreen frame? Bolt one, weld the other.
Re: Bruce McCann's Progress...
Posted: Mon Mar 01, 2010 2:33 pm
by Master Yota
Monkey Man wrote:
Is it just me, or are the rear tires mounted backwards?
I know that some offroaders set directional tires this way so that they have some traction when backing out of a mud hole, but I can't see this shining example of a restoration being used this way.
Very nice truck Bruce, very nice...
tires
Posted: Mon Mar 01, 2010 5:42 pm
by SydneyM37
you are correct about the tires ,being directional I either put up with it or have the tires removed off the rim and rotated ,predominantly the truck is on road so the groves don't touch the bitumen. Or I run the tire on the left or spare , but I want to rotate as much as often.
Bruce's truck
Posted: Mon Mar 01, 2010 7:03 pm
by ron hardin
Thanks for the response. Yeah, the bolts are there and the hod down tabs are still there. They were cut at the edge of the frame. I had started to fab the hold down and they are going to be pretty much like your pic.
Ron
Re: tires
Posted: Tue Mar 02, 2010 12:12 am
by Master Yota
SydneyM37 wrote:you are correct about the tires ,being directional I either put up with it or have the tires removed off the rim and rotated ,predominantly the truck is on road so the groves don't touch the bitumen. Or I run the tire on the left or spare , but I want to rotate as much as often.
Ahh - I failed to consdier tire rotation. Most of these trucks get driven so little that problems with the alignment rarely affect the tires.
Good on you Bruce for driving it often enough to warrant rotating the tires!
