Hard to belive its been months since I posted on this, but time has been short with little of it devoted to the M37!... But, I've found a few hours lately so here is whats happened...
The parking brake setup has been converted from the stock M37 NP200 tcase over to the NP205. With some custom machine work done to the bracket (some by a professional, and some with a zipcut) the unit fits nice and should work as reliably as a brick through a window. Here are some pics...
This was the professional machine work that needed to be done. The grooves provide clearance for the rear output bearing and snap ring on the NP205. The NP200 mount was originally flat, so the grooves from the stock NP205 bearing retainer were copied.
This is the not so professional machine work that needed to be done. The neck (seal surface?) on the NP200 output yoke is a little longer than whats on an NP205 yoke. The NP205 yoke face is also thicker. This extra material takes up the needed room for the bolt heads that attach the brake drum to the yoke to clear the bracket. The easy solution was to lop about 1/4" off the end of the bracket. The seal still fits fine, and now everything clears nicely.
Here is the drum and bracket installed.
And here is the whole works, brake band and all.
Now, I can turn my attention to building a mount to hang the NP205 under the truck. Most divorced NP205's are a pia to mount as they don't bolt to a crossmember from the bottom, but instead have the mounts cast into the top, so they hang inplace. Given the type of terrain this truck will see I figured that a hanging, unprotected tcase wouldn't be a good idea, so the mount will incorporate a skidplate framework, and provide the structure needed to mount the case. As usual with anything custom, none of the trucks original tcase crossmembers would line up anywhere close enough to be useful, so I removed them and built my own replacements. To make life easy, I took a bunch of measurements from under the truck, and then laid out the frame dimensions on a piece of plywood. This way I can build the mounts with easy reference to the space available under the truck without having to crawl under it every 10 minutes.
The tubing used is all 1-3/4" 0.095 wall HREW steel. Its easy to work with, strong, and cheap. All the bending was done on an ALLSTAR bender with a 7" radius die.
Some basic layout work, to see what fits, and what hits...
This is the rear upper tube to hang the tcase from.
Here is the front upper tube. I almost started to weld this all together, and then I had a thought. If I weld it together like this, I'll need to cut it all apart to get the tcase out. That would be a p.i.a. at best, so I needed to figure out a way to make it come apart, yet still be stout.
Here is the answer - make one of the upper bars removeable. I fabbed up some flat mounts to weld onto the tube, then drilled and sleeved the holes. Two more mounting plates welded to the upper tube and viola! one removealble mount.
The rear hoops fits nicely, lots of room around the yokes and the shift rails. I'll finish welding it all up in the next day or so, and hopefully have it under the truck by the end of the week.
Spring is just around the corner... Gotta get my arse in gear!
