by Elwood » Thu Jan 11, 2018 11:42 am
sturmtyger380 wrote:Hi Elwood, Sure only two more bolts to take off. Do you need all four of the bolts? I had two of them on the post with the support bracket but not sure if Brandon needs them or not.
Thanks, Sturmtyger 380. I won't need any of the bolts; the specs are all in MWO ORD G-741 W7, so I will source some Grade 8 replacements locally.
EDIT: Oops, the specs for those bolts are not called out in the MWO. Maybe just PM me the dimensions?
