M37 Registry Count 1063 Trucks Registered!
g741.org
M37 Discussion Forum
M37 Registry
Latest Entry
Gayle in Texas
Home Pics Parts list Production dates Production changes Contract numbers Tech Manuals Specs MilSpec Docs Links
Steering gear box rebuild
Moderators: Cal_Gary, T. Highway, nivek, robi, Monkey Man
Postby creinemann » Tue Feb 08, 2011 6:15 am
I want to rebuild my steering box, I have already replaced tie rod ends, drag link, installed repair kits, but I still want to eliminate the play I have in my steering, which I have narrowed it down to the box. My question is, can the steering box be rebuilt? Or do I need to source a new steering box. I dont want the power steering, as I prefer to keep it as stock as possible. Are there rebuild kits out there? I saw that Vintage Power Wagon has a rebuit box for $300 but I need to do it a lot cheaper than that.
Carl Reinemann
1953 M37 USAAF
1953 M101 Trailer
1961 M416
http://m37.crwdesigns.com
M37 Restoration Site
http://dodgem37.com
http://legendary-antiques.com
creinemann
Re: Steering gear box rebuild
Postby rixm37 » Tue Feb 08, 2011 9:13 am
Carl is your box still oil tight ? Have you tried to adjust the lash in the mesh ? When you turn the steering wheel does the sector shaft move back and forth before it actually moves the pittman arm? Another place to check would be the idler shaft pin and bushing.
My steering box bushing was badly worn and I got lucky and found a new empty box on ebay with a new bushing in it. I took my steering shaft and sector and put them in the new box. I got a new bearing and bottom plate from ABlinn on ebay. I got the shims and gaskets from Sid Beck but I am sure that you can get them elsewhere or make them. It was all much cheaper than 300. If you can't get an new empty box I think a machine shop can replace the big bushing on your original. You cannot get the seal for the stearing shaft but you can make one. You can get the seal for the sector shaft at a bearing and seal dealer. I can get that part# for you if you want it.
Hope this helps.
RIck
MVPA 31375
In the DOGHOUSE again
rixm37
Postby paul » Tue Feb 08, 2011 2:22 pm
seal number and explication on how to make the seal would be great!
paul
Postby M37UK » Tue Feb 08, 2011 2:30 pm
Carl, as Rick said, I hope your box is still oil tight as mine wasnt and it was just a pile of rust inside and too far gone to fix. It was almost impossible to steer and the steering was real sloppy.
I went the power steering route and have never looked back.
Cheers
Stu
MVT UK
SMVG Scotland
M37UK
Postby powerwagontim » Tue Feb 08, 2011 8:22 pm
I just rebuilt mine. John Bizal at Midwest Military had everything I needed, seals, a bearing, gaskets etc. Works like a charm!
Tim
powerwagontim
Postby rixm37 » Wed Feb 09, 2011 7:44 am
If you can get all the parts from John, that is the best approach. Make sure you take a micrometer and check your sector shaft and the clearance of the bushing in the box for a close fit. It should be within a few thousanths. The exact amount is in the chapter on the box in the power train body and frame manual. If not the new seal will eventually start to leak. When I did mine the upper seal where the steering shaft comes out was no longer available. So I made one . If you don't put a seal there oil will walk up the shaft and spill out the top. Do buy a new bottom plate as there is a seal solderd in place that you can't change. The originals had two plates with a gasket in between the new ones are a single piece and easier to install. John probably has those also.
One more thing is don't put grease in your new rebuilt box. It's made for liquid.
MVPA 31375
rixm37
Return to Technical group
Who is online
Users browsing this forum: No registered users and 3 guests
